A1
| posted on 21/11/10 at 05:00 PM |
Flasher relay
This has been covered, but Im being a bit thick...
Ive got jaguar xj8 stalks and a three pin flasher relay... how would i wire them up? i know one pin goes to earth, ones a power feed and i think the
other would go to the stalks, but cant see how this would work...
cheers
RazMan
| posted on 21/11/10 at 05:48 PM |
Does
this link
help at all?
Raz
A1
| posted on 21/11/10 at 11:08 PM |
cheers very much, ill have a good read of that
A1
| posted on 22/11/10 at 02:46 PM |
on the jag stalks theres only one supply wire, that does the main/dip and both indicators... wouldnt i end up with flashing main beam if i wire the
relay into the indicator supply? (presuming im meant to do that ) or should the relay be wired across the supply and separate indicator wires to stop
this?
RazMan
| posted on 22/11/10 at 05:29 PM |
If it has just one feed then that probably simplifies things a bit as it might has internal connections like the Sierra switch. Have you got a pinout
diag for the Jag stalks?
Raz
A1
| posted on 22/11/10 at 08:05 PM |
unfortunately not... ive wired it up with the relay on the feed, im thinking it might be okay as the main beam switch is one of the momentary ones.
RazMan
| posted on 22/11/10 at 10:58 PM |
TBH I am struggling here without any diagrams
Raz
