Lightning
| posted on 6/1/11 at 08:39 PM |
Could coil packs close to exhaust cause missfire?
As above
PSpirine
| posted on 6/1/11 at 08:46 PM |
Yes.
Plus they may be cooked now and therefore you might need to replace them.
However, it could potentially be a whole lot of other things so I'd check everything before moving/replacing them.
vyperstrype
most definatley YES!...
Coils and Coil Packs are renound to fail if they overheat. It would be better if it were located somewhere cool.
Where there's a will, there's a death!!
Lightning
| posted on 6/1/11 at 09:00 PM |
Just a thought. They are not close to the ehaust, but as mid engine when stationay after a run they could heat up in engine bay as no air flow. Just a
thought.
Strontium Dog
| posted on 6/1/11 at 09:22 PM |
Hi, you still got that misfire then? I have the coils from my T/ace (I assume they will work on your engine) if you want to try them and see if there
is any diference!
Lightning
| posted on 6/1/11 at 09:43 PM |
Yes but only when its warm
Strontium Dog
| posted on 6/1/11 at 10:06 PM |
I'd be happy to give you a hand looking at this. I enjoy a challenge. Lol! It might be worth doing a leak down test just to be sure all is well
mechanicaly. Then a coil pack swap and maybe a look to see what the mixture is doing. I've killed my wideband probe but I realy must get another
so we could fit it when I get a new one and maybe my egt as well. We would need to drill a hole in the manifold for the egt but nothing a spot weld
with the tig wouldn't heal. Mixture going lean could be the cause amongst other things.
Lightning
| posted on 6/1/11 at 10:49 PM |
I have wide band fitted
