<<  1    2  >>
Author: Subject: Megajolt map & zetec hesitating
RichardK
posted on 5/2/11 at 04:40 PM Reply With Quote
OK gang I need some help from the megajolt map experts, never had a problem with the megajolt on the pinto it just worked! However with the zetec if I floor the throttle its not too bad upto 3k then starts to coughs, judder and hesitates quite severely but if I slowley raise the revs it seems a lot better and will gradually get up to 5.5k
My map is available here Linky to map
So far I've rejetted from 1.55 to 1.75, tried the original plugs, tried the original coil pack with old ht leads, removed the air box and left the Honda cb600 hornet bike carbs open.
Is there a knobheads guide to mapping anywhere, I've looked around the auto sports website for such a thing but to no avail, like how do you work out the load bins, I'm presuming its just equal up to 100 as I'm using tps
Any ideas?
Rich
Gallery updated 11/01/2011
BenTyreman
posted on 5/2/11 at 04:50 PM Reply With Quote
Looks like your spark map is upside down. You should have more advance at low throttle openings. Also, the zetec will need less advance than the pinto does. Maximum advance in the region 24 - 28 degrees at WOT. In any case, if there is no issues with the spark quality, then it sounds more like a fuelling issue.
[Edited on 5/2/11 by BenTyreman]
RichardK
posted on 5/2/11 at 05:02 PM Reply With Quote
Meant to unplug it tonight and see what it was like in limp home mode, but forgot and my lad has now emptied the inside of a peugeot 106 onto my drive trying to fit a bass box!
Will try tomorrow, interesting comment about my map being upside down, although was the same when trying a simple 2d map, I understood that the zetec max advance was 32??
Rich
BenTyreman
posted on 5/2/11 at 05:07 PM Reply With Quote
Can't comment on the exact values for a Zetec, but I have a copy of the original spark map from an XE. Maximum advance at WOT is 20 degrees.
r1_pete
posted on 5/2/11 at 05:33 PM Reply With Quote
U2U me your email address and I'll send you the basic zetec map I had with bike carbs on a blacktop.
You'll need to alter the load bin settings, but as said, the advance should decrease as load increases, you've got it increasing.
mookaloid
posted on 5/2/11 at 05:44 PM Reply With Quote
In all fairness to Richard, ahem, errrrrrrrrrr I did that
we were trying to get it to run better and I wasn't thinking well - it was my first time with messing about with ignition curves in my defence. thinking about it - it is obvious when you consider how a normal dizzy with a vacuum advance works
RichardK
posted on 5/2/11 at 05:50 PM Reply With Quote
Think it was more of a team effort that failed tbh
Load bins? how do I find out what mine should be then?
BenTyreman
posted on 5/2/11 at 07:25 PM Reply With Quote
I have found on my throttle body setup that most of the action happens in the first 30% or so. By 30% at 2000 RPM to 3000 RPM the engine is running at maximum load, so the advance is static from 30% to 100%. Above 4000 RPM you spend virtually no time at anywhere other than full throttle or zero throttle.
Unless you get it dynoed, there are many more load and RPM bins than you will need.
I would use your existing spark map, but run the load bins the other way up. It will be close enough without taking it to a dyno to get it fully dialled in.
RichardK
posted on 5/2/11 at 07:37 PM Reply With Quote
What like this? Software wouldn't allow me to do it, so did it in notepad instead.
Rich
[Edited on 5/2/11 by RichardK]
SPYDER
posted on 5/2/11 at 08:56 PM Reply With Quote
Hi Rich.
I've just knocked this up using my 3SGE table as a base. My engine runs "speed density" so I have changed the load values to suit alpha N.
I have put max advance at WOT to 31.
Ignore all the zero value bins. My map is 12 x 12.
You need the advance at WOT to be "all in" by around 2800 revs.
Cruising conditions ie. low load, should be 8 or 10 degrees higher than WOT.
The large area of 34, 35, 36 should be able to go a little higher. I have played safe.
My engine runs 44 in the cruise area and 34 at WOT.
It should be suitable as a starting point. I'm not guaranteeing it though.
What do you think?
Geoff
[img]http://[/img]
RichardK
posted on 5/2/11 at 09:17 PM Reply With Quote
Geof thats very kind of you , thanks mate, I've stuck those into a new map and will give them a whirl tomorrow, so you disagree that the zetec's max advance is 32?
Rich
SPYDER
posted on 5/2/11 at 09:31 PM Reply With Quote
Hi rich.
I was just playing safe.
Is it seems OK let us know.
Geoff
RichardK
posted on 5/2/11 at 09:34 PM Reply With Quote
Yeh will do, will also host it for others if it works.
Rich
Just switched the bins around as the software didn't like it the other way around, shouldnt make any difference though, should it?
The above megajolt map can be downloaded from HERE
SPYDER
posted on 5/2/11 at 09:56 PM Reply With Quote
Rich, is it permitted to change the rev bins across the top line?
Geoff
RichardK
posted on 5/2/11 at 09:57 PM Reply With Quote
yes mate
SPYDER
posted on 5/2/11 at 10:03 PM Reply With Quote
Rich, does MJ have a specified advance setting for cranking or does it use the table all the time.
If so, what is your setting?
If the table seems OK we could change the top line to include a 2800 bin and tweak the cruising values a bit.
But lets not get ahead of ourselves eh?
Geoff.
RichardK
posted on 5/2/11 at 10:11 PM Reply With Quote
Is this what you mean?
and
Haven't a scooby doo what they dooooo!
Rich
SPYDER
posted on 5/2/11 at 10:19 PM Reply With Quote
The settings would suggest that your cranking advance is zero degrees.
Could you possibly put a timing light on it during cranking to confirm this?
If it is zero it might benefit from putting up to 10 degrees or thereabouts.
Ge
RichardK
posted on 5/2/11 at 10:22 PM Reply With Quote
Not sure as there are no timing marks on a zetec? I think!!
posted on 6/2/11 at 09:25 AM Reply With Quote
One thing - there is a well-known "issue" with Megajolt - the VR sensor has to be mounted on a very rigid mount. Getting ignition problems around 3000 - 4000 rpm is a recognised symptom of this problem, as the sensor vibrating can mess up the signal to the MJ controller. Beefing up the mount often makes this problem go away.
I called it an "issue", as really it's a problem with people fitting VR sensors where they were never intended to go!
RichardK
posted on 6/2/11 at 09:51 AM Reply With Quote
Worth mentioning for others but doubt its my problem as I'm using the back of the flywheel using the pre installed ford sensor, but worth thinking about as this sensor wasn't on my old flawless install, so the sensor could be iffy.
Rich
RichardK
posted on 6/2/11 at 10:54 AM Reply With Quote
Ok just been out and put that map on and also tried another map that R1 Pete sent over but sadly its still the same
I also datalogged the session if anybody under stands it, Here is the datalog
Also disconnected the mega jolt and is exactly the same in limp home mode, not sure if this is good or bad!
Connected the megajolt back up and started up the engine and changed some low end settings and the rev dropped and rose as I made changes so that would indicate that the MJ is actually changing the timing.
Thinking about getting another cam shaft sensor???
What does the collective think??
Rich
[Edited on 6/2/11 by RichardK]
mookaloid
posted on 6/2/11 at 11:10 AM Reply With Quote
time for a trip to bogg brothers?
omega 24 v6
posted on 6/2/11 at 11:18 AM Reply With Quote
Given that you originally said it was when you " floored the throttle" can we perhaps also assume that that it may be fuel related. Perhaps not enough enrichment for not long enough resulting in fuel starvation?? I don't know owt about bike carbs mind you but perhaps not enough vacuum signal to keep the fuel flowing at a higher rate for a long enough time. There was an issue with weber carbs when fitted to 16v motors that needed a rework of IIRC extra progression holes from memory. So bearing this in mind perhaps the same sort of scenario is happening here.
Given it rises OK with a steady less vigorous throttle use then maybe the spark is not the issue.
posted on 6/2/11 at 11:51 AM Reply With Quote
Rich
Ah - that'll be quite rigid then!
Are you on bike carbs? When I first fitted mine the main jets were too big, and the engine felt strangled at anything above 3500 - 4000. The plugs were badly fouled as well, all wet and black. After fitting smaller jets (and testing with an AFR meter afterwards) the engine would rev right through the range.
<<  1    2  >>
