daniel mason
| posted on 17/4/11 at 04:51 PM |
cbs wiring module help needed.
anyone running the cbs 12 way fuse +relay module?
my problem it that with a battery positive connected to the battery +ve terminal it makes terminals 15+ 13 live.t13 should only come live when
ignition on?
so which terminal should feed the ignition switch and which terminal should come live on ignition?
also the connection connected to ignition accessory point never comes live?
and none of the other terminals which should come live on ignition seem to? feed to dash etc
fuel pump primes and start switch starts the car from terminal 12 which comes live but others dont seem to so i think it could be something to do with
the ignition accessory wire? should there be a feed to this unit from an ignition live which in turn feeds various terminals? cheers
MakeEverything
| posted on 17/4/11 at 05:12 PM |
This should help?
Kindest Regards,
Richard.
daniel mason
| posted on 17/4/11 at 05:29 PM |
i have that mate but am using the honda ignition switch and start button.
there is a feed to terminal 6 but terminal 13 is permanent live and stays live with ignition off!
terminal 10 does not come live when ignition on
t 12 does which connects fuel pump and also feeds starter. so the car at leaste starts,runs and sounds awesome!!!
think the wires connected to t 13 + 15 are linked and should not be. but looking at that diagram i cant see where the feed comes in which feeds all
the other terminals like dash +ve, radio etc? i was looking for somewhere to feed the wideband but ended up connecting it to t12 with the other wires
to get it working. i think it could be t10 which feeds these,but for some reason is not coming live!
MakeEverything
| posted on 17/4/11 at 06:18 PM |
The way i read this is;
Battery live to T13 and T6
Ignition (sw live) connected to T15
Is that how youve got it wired?
Kindest Regards,
Richard.
daniel mason
| posted on 17/4/11 at 07:11 PM |
no, on the other sheet of wiring which comes with that sheet it says t13 only comes live when ignition on. i am sure t15 is permanent live as this
feeds from t6.and livens up a few terminals which have to be on with no ignition, eg hazards!so i think this feds the ign switch.then back to t13. but
the accessory live which is connected to t10 does not come live at all.
my car has been away for ecu to be wired up and these connections were done by them. so i am trying to fault find now to get it correct
