MakeEverything
| posted on 19/4/11 at 05:41 PM |
Anyone know much about Emerald M3D?
Looking to buy one, but not heard anything about them before other than the name.
Kindest Regards,
Richard.
blue2cv
| posted on 19/4/11 at 06:20 PM |
Had one on my turbod and injected 2cv, Dave and Karl modded the M3D to suit my little 2 cyl engine, worked good, i expect they have improved them
since i had mine in 1999, that little car really used to pee people off, was running over 70 bhp, std was 30, now if i could only make time to do some
work on the blackbird powered one.
lsdweb
| posted on 19/4/11 at 06:22 PM |
Excellent piece of kit. Excellent service.
Lots of rolling roads used to mapping them too which is an important factor to consider!
Wyn
| posted on 19/4/11 at 06:59 PM |
I have an Emerald ECU on my car, easy to get running and change settings , good back up if needed but worth getting the car set up on a rolling road
for final set up like any other ECU . Might be worth having a read of Dave Walkers book on engine management which also comes with a CD so you can
practice setting it up without needing to connect it to the car. Emeralds rolling road is in Wooton , Norfolk so not too far away from you
zetec
| posted on 19/4/11 at 07:16 PM |
First class bit of kit and as said backup first class too. If I needed to get another ECU Emerald would be my first port of call. Dropped in once with
a set of injectors for testing, they stuck them straight on their test rig and checked them for me while I waited, all for a donation to their Tea
fund.
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
MakeEverything
| posted on 19/4/11 at 07:18 PM |
happy days, thanks fellas.
Kindest Regards,
Richard.
will121
| posted on 19/4/11 at 07:25 PM |
ive got one and find it easy to understand and as said found them to be more than helpfull, however whether they are better than someone like omex i
do not know, i chose a Emerald as they are local to me so getting help amd mapping was easy, i would also look to see what ECU's your local RR
map and their service before specifically chosing one make though
