Author: Subject: main battery leads
daniel mason
posted on 10/6/11 at 05:45 PM Reply With Quote
main battery leads
will a 16mm squared main battery lead be big enough to do the job or will i need bigger? vehicle wiring products only do a 16mm battery lead and 19mm earth! cheers
snowy2
posted on 11/6/11 at 08:35 AM Reply With Quote
it'll be fine unless your putting the battery in the boot and the engine is up front......then you might want a larger wire.....might. you will be fine.
daniel mason
posted on 11/6/11 at 08:39 AM Reply With Quote
tanks snowy! very helpful.
