Author: Subject: Digital Speedo set up question
mcg
posted on 18/6/11 at 04:03 PM Reply With Quote
Hi - I am just installing my KOSO DB02R speedo, and have a quick question:
Should it have a perminent power supply so that it can retain its set up info? From what I see from the wiring diagram it looks like power is only provided when the ignition key is turned on?
I did notice that it has a battery compartment, so wondered if that would be the intended solution?
Hopefully I wont have to ask too many questiions to get this installed!!!
Thanks as always.
Matt
Stuart_B
posted on 18/6/11 at 04:10 PM Reply With Quote
hi matt, i do not have that koso dash, but do have a koso dash, and mine has no perminent power supply, as you said it has an internal memory, so it keeps all its info.
hope that helps
cheers
stu
mcg
posted on 18/6/11 at 05:15 PM Reply With Quote
cool - makes sense! Thanks alot.
