mcg
| posted on 20/7/11 at 11:21 AM |
Digi Dash limitations
hi - I have a Koso Digidash which has 2 temp sensors. My plan is to use one for water which is a simple job of removing the old temp sensor in the
engine and replacing.
Where I am stumped is for the oil. On the bottom of the engine there is a sender unit with a single terminal. I am lead to believe this is a low
pressure switch which will illuminate a warning light if there is low pressure? Is that right?
If so, is it a good idea to be able to have a reading of oil pressure and temperature? If so, do I need speparate sensors and gauges?
What have you digi dash people done????
MikeFellows
| posted on 20/7/11 at 11:26 AM |
just add a spacer inbetween the pressure sensor and the block with a nptf thread to add your temp sensor
MikeFellows
| posted on 20/7/11 at 11:29 AM |
found these too
Clicky
monkeyarms
| posted on 20/7/11 at 12:18 PM |
or a oil fillter sandwich plate?
mcg
| posted on 20/7/11 at 01:16 PM |
ok cool - is this something that you have done?
Also what gauge did you use that fits style wise with the minimal digi dash - dashboard that you have?
