r1_pete
| posted on 24/7/11 at 01:56 PM |
EDIS Pin 2 for tacho drive
I'm just planning my megasquirt installation, and rather than messing with tacho driver circuits, I was thinking of using the EDIS unit pin 2
which is a tach feed back to the ECU as stock.
Is anyone doing this, tried it, have any experiance etc??
Cheers.
Pete.
AntonUK
| posted on 24/7/11 at 02:34 PM |
i've done it, drilled out the blank and shoved a wire in the hole worked for years
JAMSTER
| posted on 24/7/11 at 02:47 PM |
i used pin 11 but to drill out the blank and move a wire
[Edited on 24/7/11 by JAMSTER]
ChrisW
| posted on 24/7/11 at 04:18 PM |
Not sure which pin number it is, but it's the one between the coil wires on an EDIS4. It works perfectly well. As said, if the original car
didn't have a tacho the pin will be blanked but you can take the connector apart and fit your own wire in the position.
Chris
scudderfish
| posted on 24/7/11 at 08:21 PM |
It's how I run my tacho.
ashg
| posted on 24/7/11 at 08:42 PM |
which version of ms do you have? my ms has a tacho out which gives exactly the same signal as the edis4
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
