omega 24 v6
| posted on 29/8/11 at 10:11 PM |
Dash2 setup for fuel gauge
I cannot get the fuel sender readings to show the required outputs on the display.
I have done the voltage potential divider as said in this post
http://www.locostbuilders.co.uk/viewthread.php?tid=159999
But when I generate an equation from a graph
I enter the following figures which should give me the outputs in litres
voltage 0.18 output 50
voltage 1.17 output 37
voltage 1.86 output 25
voltage 2.41 output 12.5 ( this is the current fuel level ( ish)
voltage 2.54 output 0
However when I generate the equation and upload it to the dash the output figures are crap I expect to see 12.5 litrs but see something else . in fact
its always the last number of the equation not the same as BUT LIKE like the one in this table (156.79)
http://www.race-technology.com/wiki/index.php/HowDoI/ConnectMyOwnSensor?action=print
Where am I going wrong.??
[Edited on 29/8/11 by omega 24 v6]
jeffw
| posted on 30/8/11 at 05:48 AM |
How have you arrived at your figures ? Are you taking a separate feed with pull up resistor from the reference 5v?
This is interesting
http://www.race-technology.com/wiki/index.php/HowDoI/ConnectMyFuelSender
Running through your calculations using this potential divider calculator http://www.random-science-tools.com/electronics/divider.htm suggests your
12.5L value should be 2.14V not 2.41V. 2.41V would be around 4L not 12.5 if the curve was the same through out.
[Edited on 30/8/11 by jeffw]
omega 24 v6
| posted on 30/8/11 at 06:04 AM |
We pulled out the sender from the tank and read the voltage with a metere at the 4 positions. empty 1/4 1/2 3/4 and full. yes I have a 330 ohm pull up
resistor in place. its really strange as I do understand the theory but its just lacking something somewhere.
The figures are a guess ish at different float levels held by hand but the voltages are real. Should I measure the resistances at the voltages and
divide it into 4
i.e. empty 1/4 1/2 3/4 and full across the 300 ohm range and apply the voltage for each setting?
[Edited on 30/8/11 by omega 24 v6]
jeffw
| posted on 30/8/11 at 06:18 AM |
If you don't include the 12.5L value do you get a sensible curve/equation and then reading?
Ahh OK....the 2.41 is a typo and not what you entered.
Have you connected up to the DASH2 with the lite monitor on a laptop and seen the actual voltage you are getting? Might be worth taking the sender
out and wiring it to the DASH2 and using the actual voltages you see on the Lite Monitor. The proper way to do it would be to empty the tank and fill
in 5L intervals while using the Lite Monitor to measure voltage.
omega 24 v6
| posted on 30/8/11 at 06:27 AM |
not used the lite monitor is it part of the dash software or do you need to download it.
Might have to empty the tank perhaps then.
he also has the can bus wiring for the ecu to dash and god knows how the hell I'm going to do that as it looks total double dutch to me LOL
jeffw
| posted on 30/8/11 at 07:06 AM |
Lite Monitor is part of the software download package from Race Technology. The ECU connection is easy in comparison.
I'd check with the Lite Monitor what the DASH2 is actually seeing on that channel and then either guess the other values or drain the tank.
omega 24 v6
| posted on 30/8/11 at 11:21 AM |
Doesn't look it???? hexadecimals etc and i'm lost. Unless its already programmed to give the outputs to the dash2 them i'm gonna be
fecked.
its a DTA s60 ecu and I need outputs for water temp rpm and oil pressure.
jeffw
| posted on 30/8/11 at 08:11 PM |
The page for the S40 looks easy so I assume the S60 would be the same.
Setup the S60 as shown here
http://www.race-technology.com/wiki/index.php/ECUType/DTAS40ECU
Setup the DASH2 using the RT software and select the ECU inputs (input scaling/5.ECU inputs) in the relevant screens (RPM, Water Temp etc).
Edit the name if you want to and then config up the specific Display Screens to show the relevant ECU data. The S60 will display
Name Race Technology Channel Resolution
RPM Engine Speed 25 RPM
Air temp Ambient air temp 0.1oC
Water temp Water temp 0.1oC
Throttle Throttle Position percentage 0.1%
Manifold pressure Boost pressure 10 mBar
Lambda Lambda1 0.01 Volts
Bat Volts battery voltage 0.01 V
Oil temp Oil temperature 0.1oC
Oil Pressure Oil pressure 10 mbar
Fuel pressure Fuel pressure 10 mbar
Send the config to the DASH2 and then connect the ECU to the DASH2 via the RT ECU cable.
Simple with no Hex.
omega 24 v6
| posted on 30/8/11 at 09:10 PM |
Okay so fuel is now working OK add scaled. It was a loose connector 1 which was losing signal to analogue 4.
As for the Can I must be doing something wrong.
As you say the screen has ecu temps on it BUT whenever i select the water temp from the ecu and update the dash there is nothing there. It shows on
the screen on the pc ( just as yours does ) but nothing actually on the dash.
I still have to do the oil pressure setup ( waiting for a sender to come) with the equation ( which I now know I was doing Ok all along).
but the canbus thing is just not working right. perhaps I need to change settings in the ecu ( rs232 streaming? or can bus streaming?)
ETA I found this perhaps it's what needs to be done to the ecu software do you think??
http://www.aim-sportline.com/download/ecu/racing/aim_DTA_S_Series_100_eng.pdf
beaver34
| posted on 30/8/11 at 09:34 PM |
not a clue, but reading as im doing mine in the next few months so i wish you luck! what tank sender you using?
omega 24 v6
| posted on 30/8/11 at 10:34 PM |
std clio tank sender 0 to 300 ohms
jeffw
| posted on 31/8/11 at 04:04 AM |
Gary
You need to config the S60 and turn on it's logging as shown on the top of this sheet
Once you have done that you should see data. Again check with the Lite monitor to see if you get anything.
When I was setting mine up this was very useful for the non-ECU sensors.
http://westfield-world.com/rtdash2.html
jeffw
| posted on 2/9/11 at 12:12 PM |
Any joy Gary?
