Mr C
| posted on 27/12/11 at 12:48 PM |
What Sender units for RT Dash2?
I need Turbo Boost, oil pressure and water temp senders for my Subaru engined project. Does anyone know what type to use which would use the available
RT software settings and fit the engine? Or an alternative source for the same senders? Total cost from RT is £214 +VAT for three senders and wires
which seems a bit steep to me.
[Edited on 27/12/11 by Mr C]
Girl walks into a bar and asks for a double entendre, so the barman gave her one
daniel mason
| posted on 27/12/11 at 01:08 PM |
what ecu are you using?
you can wire them derectly into loads of the decent ecu's and send them to the dash 2 using canbus. think the dash only has about 4 analogue
inputs if wiring to dash.
Mr C
| posted on 27/12/11 at 01:28 PM |
Its a standard UK Subaru ECU no canbus etc, so direct connection is not an option. The car hasn't any senders fitted for boost or oil pressure
and has a one wire temp sensor which would involve messing about with resistors and manually calibrating the dash.
daniel mason
| posted on 27/12/11 at 01:39 PM |
im finding my dash 2 way too complicated to workon and set up. its really high tech stuff and you need to be a bit geeky to get it set up properly
snakebelly
| posted on 27/12/11 at 03:56 PM |
Try this guy, its who we bought our dash, data logger and Can cable from and he also supplied some sensors at reasonable prices.
Mr C
| posted on 27/12/11 at 09:59 PM |
Have you a link or contact details Snake?
daniel mason
| posted on 27/12/11 at 10:08 PM |
hes probably on about andy chalmers. he sells loads though ebay and is really helpful. but id wait until after new year to call.
femster87
| posted on 27/12/11 at 11:51 PM |
Not too hard to calibrate senders as long as you know their operating ranges and select your pull up resistors correctly. speak to race technology
they are very helpful
Mr C
| posted on 28/12/11 at 10:39 AM |
As mentioned, I don't have sender units for the boost or oil pressure and would prefer ones that can be pre programmed with the RT soft ware
rather than working out values, operating ranges, plotting graphs and messing about with resistors, Cheers.
