beaver34
| posted on 21/1/12 at 09:44 PM |
Starter motor and alternator
Want to wire my starter up tomorrow, anyone got an idiots guide how to do this in terms or where the cable goes to and from
Also same for alternator, I have fia cutoff switch to sort
[Edited on 21/1/12 by beaver34]
snowy2
| posted on 22/1/12 at 09:12 AM |
This really could not be simpler......big chunky wire to the large bolt on starter (if pre engaged starter not the one that has a wire already on it)
to the battery. if the isolator is connected then the starter goes to on of its terminals and the other to the battery. for the starter iniator wire
just connect the starter as above and fit to engine then take a temporary wire from the battery +ve terminal and touch one of the small connectors on
the starter, one will cause the starter to kick in and start the engine to turn. that is the "starter" wire...simples......
here is a link to an article i wrote years ago showing how to rewire a car.....
http://www.andersensmith.freeserve.co.uk/wiringloom6.pdf
it may be of help to you.
The alternator connects via the large chunky charging wire to the battery OR the starter motors battery connection.....IT DOES NOT MATTER. the charge
excite wire connects to an ignition switched live usually from the ignition switch to a bulb (battery light) and from the other bulb connection to the
alternator.
[Edited on 22/1/12 by snowy2]
sometimes you are the pigeon, most of the time the statue.
