lsdweb
| posted on 19/4/12 at 10:56 AM |
Flashing an LED
Hi All
I have an LED shift light (ignition feed and switched earth by the ECU).
I want to be able to make this LED flash in a certain circumstance - any thoughts on a simple option?
Ta
Wyn
omega 24 v6
| posted on 19/4/12 at 11:17 AM |
Not sure what you mean really?? If its controlled by the ecu the you will need to add an aditional circuit to make it flash. If you want it to flash
when the ecu close the earth sitch then just buy a flashing LED (all the circuitry is built in to it). I have a flashing high output led for my oil
pressure switch.
lsdweb
| posted on 19/4/12 at 11:29 AM |
Yeah, sorry, not very clear!
I want it to work as a normal shift light, controlled by the ECU, but I also want it to flash (when I select a certain engine map which is my
startline map )
So what I need is some kind of simple circuit to switch it to earth on/off/on etc...
I could use a relay but that seems like overkill!
Ta
Wyn
omega 24 v6
| posted on 19/4/12 at 11:49 AM |
OK so when you select your startline map then your ecu would need to send a signal/ output to one of its pins in order for you to do this. OR be
programmed internally to do it on the existing shift light pin.
I'm not sure if this is possible though. You wont get it to flash on one map, and not the other, without the ecu telling it to though IMHO.
[Edited on 19/4/12 by omega 24 v6]
lsdweb
| posted on 19/4/12 at 11:55 AM |
I'll use a double pole to switch the map so the switch can control the 'circuit' fr the flashing lamp independently of the ECU.
Or I could just fit a separae flashing LED I guess!
big-vee-twin
| posted on 19/4/12 at 12:03 PM |
Its very easy - just buy a flashing LED link
http://www.triangleltd.com
stevebubs
| posted on 19/4/12 at 12:20 PM |
555 timer...
stevebubs
http://wild-bohemian.com/electronics/flasher.html
| posted on 19/4/12 at 01:22 PM |
Yup. 555 timer on astable mode, simple.
omega 24 v6
| posted on 19/4/12 at 04:42 PM |
loop from light wire to double pole double throw switch ( for map change) and from switch to electronic flasher relay ( the one we all bang on about
for led indicators) wire relay as required.
iank
| posted on 19/4/12 at 04:55 PM |
12V flashing LED and a double pole switch for the map switching.
Anonymous
AntonUK
| posted on 19/4/12 at 09:07 PM |
quote: Originally posted by stevebubs
555 timer...
agreed... 555 and a bit of veroboard... JD
Build Photos Here
lsdweb
| posted on 19/4/12 at 09:15 PM |
Lots to think about - thanks guys!
Get the car home tomorrow so time to plan the looms / dash etc.
