MikeFellows
| posted on 8/5/12 at 09:22 PM |
Definative Switch/warning light List- IVA Friendly
guys i searched and cant find a definitive switch list I appreciate everyone's needs are different but there must be a common theme for cars
wishing to pass IVA, my motivation for this is purely im about to order my switches and dont want to miss any and pay postage twice, and thought it
could be useful for others
so here goes
General:
1. Engine Start (or key) - if switch should be momentary
2. Driving Lights - requires warning light either in switch or separate light - latching switch - warning light must be green???
3. Headlights - requires warning light either in switch or separate light - latching switch - warning light must be green???
5. Main Beam - requires warning light either in switch or separate light - latching switch - warning light must be blue???
5/6. Indicator Right / Left (or stalks) - one warning light for both switches - if switch should be latching
7. Hazard Lights - Requires warning light in switch or separate light - latching switch - warning light must be red???
8. Horn (or on steering wheel) - Momentary switch
9. Brake Fluid Warning Light - Warning Light Only - Must be red???
10. Fog Lamp - Only works when Side Lights / Main Beam are active - Latching Switch
If Windscreen Fitted:
1. Wipers - could someone confirm if different speeds of wipers are required for IVA? - Latching Switch
2. Windscreen Wash - momentary switch
BEC:
1. Reverse Button - Momentary switch
Optional: (im sure there is millions of things i could put in here)
1. Radiator Fan - Latching
Im happy to add anything, though Im not sure how long i can edit the first post for?
[Edited on 9/5/12 by MikeFellows]
blakep82
| posted on 8/5/12 at 09:36 PM |
here's a photo showing all of mine. my auto electrician came ot measure up for my loom and agreed i'd got everything i need
so in the big black plate,
indicator (green), hazard (red), main beam (blue), brake fluid (red) with push button switch, indicator (green)
side/headlight warning can be the gauge illumination or a green lamp
big starter button in red, horn button on the other side in smaller red
two smaller plates are fuel gauge and rev counter
toggle switches down the side, top to bottom:
indicators left/right
headlights off/on1/on1+2
main/dip switch
fog with small amber led warning to be glued in
the 2 holes next to the toggles, one will be a key switch, the other blanked off
the two at the bottom, 1 red charge light, one amber oil pressure
there is a hazard switch missing in that photo though, but Richard from World of Wiring reckons i've got everything covered there
________________________
snapper
| posted on 9/5/12 at 05:17 AM |
Add fog lamp switch which must only be switchable when side lights (and driving and full) are on
Hand brake & brake fluid can be combined using handbrake switch as test switch for fluid level
[Edited on 9/5/12 by snapper]
I eat to survive
I drink to forget
Daddylonglegs
| posted on 9/5/12 at 08:12 AM |
I thought that the Fog was not supposed to come on with sidelights only, just Dip and Main beam?
russbost
| posted on 9/5/12 at 11:09 AM |
seconded!
mad4x4
| posted on 9/5/12 at 02:45 PM |
seconded!
+1
Scot's do it better in Kilts.
MikeFellows
| posted on 9/5/12 at 02:57 PM |
thanks guys, I will keep this updated as people post, i was sure there was a time limit on editing first posts but apparently now
Irony
| posted on 9/5/12 at 09:39 PM |
watching this thread with interest because I am at this very point in my build.....cheers
