Author: Subject: MX5 and savage switches
rdodger
posted on 21/6/12 at 03:18 PM Reply With Quote
Any one help me with this?
There seem to be too many contacts on the MX5 to use a Savage switch.
Any ideas?
Wiring diagram is here
http://www.madracki.com/miata/images/wiring/99sys.pdf
[Edited on 21/6/12 by rdodger]
Ben_Copeland
posted on 21/6/12 at 03:37 PM Reply With Quote
Which switch? Most are simple + and -. Are you talking about hazards? Or headlights etc?
Ben
Locost Map on Google Maps
Enter Your Details Here
rdodger
posted on 21/6/12 at 03:41 PM Reply With Quote
Oh sorry. It's the Hazard wiring.
BigLee
posted on 21/6/12 at 05:08 PM Reply With Quote
Are you using the full MX5 loom? Or building your own to suit? I have a Savage switch on mine and as I remember is was quite straight forward.
rdodger
posted on 21/6/12 at 05:28 PM Reply With Quote
I'm using the MX5 loom.
It does look straight forward until you see there is an extra pole in the mazda switch.
BigLee
posted on 21/6/12 at 05:41 PM Reply With Quote
I think I have 3 wires. Positive, Earth and the light. Although I must admit trawling through those diagrams did nothing for my sleep! In the end I left stuff like that and the column switches till last. Sat in the car for about 4 hours with one of those sharp pointy testers. I had some Mk2 switch gear on a Mk1 loom. Part guess work!
rdodger
posted on 21/6/12 at 05:52 PM Reply With Quote
Was yours a mk1 loom?
BigLee
posted on 21/6/12 at 06:11 PM Reply With Quote
Yes. Not sure of all the differences, but it wasn't plug and play when it came to the column controls. Lots of cutting, soldering and heat shrinking. I had the loom prepared for me by MNR's sparky. Had to cut chunks out though as it was massive!
rdodger
posted on 21/6/12 at 07:07 PM Reply With Quote
The MK1 has 2 wires to the switch. The MK2 has 6.
Steve Hignett
posted on 21/6/12 at 07:08 PM Reply With Quote
Just make your own mini loom for the Hazard switch, would be the simplest solution...
Steve Hignett
posted on 21/6/12 at 07:10 PM Reply With Quote
I think I have one in here - can't check at the mo!
http://locostbuilders.co.uk/photos.php?action=gal&user=worx&folder=Wiring Diagrams
If that doesn't work, try:
[Edited on 21/6/12 by Steve Hignett]
