Ivan
| posted on 8/8/12 at 06:51 AM |
Timer to leave circuit on when switching off - advice needed
Oops - hit wrong key and posted before message was typed.
I have fitted a wideband O2 sensor to my Cobra and unfortunately the only place available means it is sloping the wrong way making it perfect to catch
condensation.
I thought that maybe a small timer on it's heater circuit that would come on say a half hour after turning off ignition and then switch off say
half an hour later might stop condensation.
Anybody know of a suitable timer and if that idea would work?
[Edited on 8/8/12 by Ivan]
snakebelly
| posted on 8/8/12 at 06:58 AM |
less than 1 hour more than 1 minute i reckon,
HTH
mark chandler
| posted on 8/8/12 at 07:34 AM |
Turbo timer maybe, not expensive although doubt you will get one for 1/2 hour, this seems excessive, a few minutes maximum I would have thought.
loggyboy
| posted on 8/8/12 at 08:13 AM |
Simple 555 timer circuit from maplin with a wiring digram from tinternet...
Mistral Motorsport
| posted on 8/8/12 at 08:56 AM |
You can find ready made 12v timers on eBay they are very versatile that countdown after an input is switched off.
The time delay can be pre-set with dip switches,
I have seen them use to turn off troublesome SRS warning lights after a 4 second delay.
| posted on 8/8/12 at 09:21 AM |
Some cars use a small electric water pump that runs for some time after the engine is switched off, probably controlled by a timer relay , Renault 19
16v springs to mind and I'm sure other cars possibly some Volvo's have them fitted. Might be worth a look?
snakebelly
| posted on 8/8/12 at 11:08 AM |
actually, despite my tongue in cheek replky i am also interested in this, want to run an aux water pump on a timer when i switch the car off, would
this do the job? bit of an electronic numpty so any guidance greatly received:
H-TRONIC ELECTRONIC TIMER RELAY UNIT MODULE 12 V/DC 100 mA 72 x 88 mm BRAND NEW | eBay
snakebelly
| posted on 10/10/12 at 12:35 PM |
think i found something that will do the job, its avalable here, have one here now just need to test it
https://www.spiyda.com/magento/index.php/vehicle-electronics/other-vehicle-electronics/dual-fan-controller.html
Ivan
| posted on 11/10/12 at 11:22 AM |
Thanks for that - neat Idea linking it to engine temperature.
