monck
| posted on 26/8/12 at 09:07 AM |
Is it possible to run two rev clocks ..
Hi i would like to know if i could run two rpm gauges as the one in my dash is out of view when driving i want to mount a small one up on my dash ..
is this possible or can it not be done ?
Might be a stupid question but thought id ask before getting one ..
Ryan
[Edited on 26/8/12 by monck]
Neville Jones
| posted on 26/8/12 at 10:47 AM |
I've done it using a few transistors, just to isolate each signal.
| posted on 26/8/12 at 11:20 AM |
The rpm signal is quite robust, I'd imagine even just sticking a few diodes in would do the job.
blakep82
| posted on 26/8/12 at 12:58 PM |
what ignition are you using?
i've got a megajolt, with edis 4, and if i remember right, both the edis and megajolt both have rev counter outputs
you've got throttle bodies i see, but no mention of what ignition system. if a megasquirt, have a look through the wiring maybe you have 2
seperate outputs too?
I've got more of a shift light type thing. the megajolt has 4 user outputs and 1 shift light output, so i've got 5 LEDs, each of the 4
user outputs to come on an a different RPM, and the shift light set to an RPM too
________________________
maccmike
| posted on 26/8/12 at 02:18 PM |
Iv got a rev gauge and a digital dash, but im on carbs not throttle bodies if it makes a difference.
monck
| posted on 26/8/12 at 07:38 PM |
Yes i have Throttle bodies run on a Megasquirt 2 v3 ecu if that makes any diffrence .. so it seem's it can be done ?
