mad-butcher
| posted on 15/9/04 at 05:38 PM |
robin hood harness
bought a vicky green harness for my indy blade having a devil of a job understanding their chart...the problem is with the relays on latter type
switches
they say common power to pins 86 87 pin 30 to head light pin 85 to switch.... on my pinto indy with premier wiring harness 85 and 86 are common power
30 is power in and 87 is power out
which is the correct way to wire up the relays on type 87 switches (later ones)
many thanks in advance
tony
Deckman001
| posted on 15/9/04 at 05:55 PM |
Would whole heartedly recomend 'Premiere' looms, have installed one for a friend and am doing the same to mine, believe premiere!! look
at the info with the prem loom, it gives advice on both the 83bg and the 87bg, one is switched earth , the other is switched pos, it makes a big
difference
Jason
mad-butcher
| posted on 15/9/04 at 07:42 PM |
the great thing with alan at premier is that he will wire the plugs up to the harness when you order the harness and send him the switch plugs i think
he charged me a tenner
