steve m
| posted on 2/5/13 at 04:09 PM |
What connecters do i need (jump lead)
I am after some electrical connectors, that can be fitted to the sportscar, in a convienent position with out removing the bonnet, and also my jump
leads,
But what are these connectors called ?
regards
steve
omega 24 v6
| posted on 2/5/13 at 04:29 PM |
Anderson connectors. Will look for some piccies for you
Here you are. Use them on mines. Frome battery to one of these and then from there to a set of crocodile clips . This allows you to jump your motor
from another and vice versa. I also have made one from my battery charger so I can plug it in over winter to keep the battery conditioned.
[Edited on 2/5/13 by omega 24 v6]
Oops forgot link
http://www.dun-bri.com/power_management/high_current_power_connectors/175_amp/11249/
Is this to connect a battery conditioner when the cars not in use?
steve m
| posted on 2/5/13 at 04:37 PM |
Anderson connectors appear to be the style i was after, but do they come in pairs, ie male and female ?
It was more so i can jump, or jump another car without taking the bonnet off,
omega 24 v6
| posted on 2/5/13 at 04:48 PM |
Not in pairs you just buy 2 if you look at the pic they are marked + and - You then take one rotate it 180 degrees and turn it upside down. Then the
+ and - are aligned again. Solder or crimp the terminals to the wires and slide them in from the back the correct way up and a metal tang locks them
in place ( can be removed if you want if you get them wrong as well) We use them at work all the time as tailift connectors between artics and
trailers.
adithorp
| posted on 2/5/13 at 05:48 PM |
Powervamp usually have them at Stoneleigh show. There's several different
CONNECTORS
(Link doesn't go direct for some reason. They're on page 6)
[Edited on 2/5/13 by adithorp]
http://jpsc.org.uk/forum/
