Dooey99
| posted on 17/10/13 at 06:04 PM |
Resistors in a fuel sender circuit
My question tonight is...
I have a fuel sender which is 18 ohms full and 268 ohms empty I need this to be 0 ohms full and 250ohms empty, to work with my acewell dash, is this
possible? I don't really want to buy that fuel sender wizard thing
Less weight more speed, more power more speed
If in doubt, give it a clout
| posted on 17/10/13 at 06:54 PM |
No, you can't get it down to zero ohms with a simple resistor network. A 3700 Ohm resistor in parallel with the sensor will move it's
range to 17.9 -250 Ohms. However the sensor is close enough to the nominal 250 ohms that it should work perfectly well with the Acewell gauges
without any resistors.
Dooey99
| posted on 17/10/13 at 07:13 PM |
Okay that's where I start getting confused. The gauge has 7 bars I think but the top bar won't work! The rest do and the bottom one
flashes when it is low low. I can power up the top bar by doing away with the sender. Any suggestions this is the second sender I bought
big-vee-twin
| posted on 17/10/13 at 07:21 PM |
Unfotunatly not I tried for ages with different arrangements but they just don't work. You get one end right but not both.
You need the wizzard I reccomended to you in your previous post or a matching sensor.
http://www.triangleltd.com
Dooey99
| posted on 17/10/13 at 07:31 PM |
Boll0cks, did you buy the wizard? I can't find a matching sensor anywhere I was searching for at least 2 hours the other night. I'll
either buy the wizard or hust have 6 bars on my gauge.
big-vee-twin
| posted on 17/10/13 at 08:06 PM |
Yep, here it is fitted to the rear of my dash panel
[img]
  dashboard wiring
[/img]
[Edited on 17/10/13 by big-vee-twin]
gremlin1234
| posted on 17/10/13 at 08:09 PM |
can you adjust the float hight manually? - ie bend the arm down a little?
scudderfish
| posted on 17/10/13 at 08:20 PM |
Paint over the top LED and make is a 6 element one
