davef
posted on 3/10/02 at 11:13 AM |
voltage stabiliser
hi guys what i need to know is do i need a voltage stabiliser in the loom for the gauges ie petrol oil water & tacho, i am using a lucas alternator cw
regulator cheers davef.
Big Stu
| posted on 3/10/02 at 04:29 PM |
Alright? Yes you do need a regulator otherwise the petrol gauge will read full and it is empty and the temp and oil will hadly move. I think you will
be able to get something from lucas. If anyone knows what is required it would be great as I have the above problem.
stephen_gusterson
| posted on 3/10/02 at 05:50 PM |
it will depend completly on the guages you use.
if they are really old you will need a reg.
the vdo ones i bought new run right off 12v.
atb
steve
Big Stu
| posted on 4/10/02 at 06:07 AM |
Triumph Dolomite, so yes they are old anyone know the correct voltage for these?
theconrodkid
| posted on 5/10/02 at 04:58 PM |
they run on 9 or 10 volts from memory,all lucas,bl group used the same stabaliser,plenty around,i probly got some if you cant find one
JohnLocost7
| posted on 3/11/02 at 12:26 PM |
Try Holden
www.Holden
They even have wiring diagrams.
Part No 070.019
chrisg
| posted on 3/11/02 at 01:51 PM |
They're 9v - got mine from the local Lucas place - about £8 from memory, or from a dead dolomite - it's fixed to the back of the seperate wooden
dash bit in a bracket.
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the
error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
