blockpower
| posted on 26/6/14 at 05:41 PM |
Water Temp Gauge Reads Too HOT but it's not
My temp gauge reads hot even though the engine is operating within normal parameters. The engine never overheats I'm wonfdering if it is just
the sensor could somebody give me some advise please?
2000cc Zetec smiths 52mm gauge.
Many thanks
big-vee-twin
| posted on 26/6/14 at 05:55 PM |
Is it a Smiths sensor matched to the guage?
http://www.triangleltd.com
micksalt
| posted on 27/6/14 at 08:53 AM |
Is there enough free cable in the wiring loom to dangle the temperature temperature sensor into a cup of water? I used this technique to diagnose a
fault in my daily driver. With the sensor removed, but still wired up to the loom, I dipped it in cups of water of varying degrees of temperature
whilst simultaneously taking a reading with a known, good electronic thermometer. Turns out that although the cold and operating temperatures were
right, it had lost linearity in the warming-up region.
alfas
| posted on 10/7/14 at 10:08 PM |
zetec ususally does not have a (free) thread where you can screw-in a typical smiths sensor.
have you upgraded your car from a x/flow or pinto to zetec?
yes? than you should have kept the "old" sensor, installing it in something like this:
you can find them at ebay
cliftyhanger
| posted on 11/7/14 at 05:58 AM |
Many older smiths gauges run off a stabilised 10v supply and need a specific sender. 12v will cause it to overread....
alfas
| posted on 11/7/14 at 08:37 AM |
original one
modern one:
alfas
| posted on 11/7/14 at 08:38 AM |
if the instrument is connected direclty to power (12V) it will read too high
alfas
| posted on 14/7/14 at 07:05 AM |
here sale´s link of those modern stabilisers:
Semiconductor Voltage Stabilizer- GT6 Spitfire Stag 250
