belgian2b
| posted on 13/1/15 at 05:14 PM |
ETB Speedometer not working
Hello,
my tiger kit car has an ETB electronic speedometer.
It was working correctly.
Since a few days , i noticed that sometimes the needle was not moving.
i had to knock the glass and it started again correctly.
today as the weather was good, i went to my local MOT station( i am in Belgium) because i need to re-register.
So , when testing the car, they noticed that the digital display that shows the distance was not working.
So, what can i do ?
is there something i can check by myself ?
I sent an e-mail to ETB but i suppose that i will need a few days to get an answer ?
Gerardo
PAUL FISHER
| posted on 13/1/15 at 08:12 PM |
The ETB are prone to damp, if they have been in a cold damp garage etc, a well know trick that has been known to work is, to remove it and put in a
warm place for a couple of days, a boiler cupboard is ideal.
belgian2b
| posted on 14/1/15 at 07:30 AM |
Ok, i Will try this .
Thanks,
Gerardo
Chris_Xtreme
| posted on 14/1/15 at 01:38 PM |
I have the same problem on mine, the lcd display stops working.
It does dry out and then works, then fails again!
annoying.
I ended up using my phone as a GPS speedo / odometer when it was going wrong.
