rdodger
| posted on 11/10/15 at 02:32 PM |
Current draw
Afternoon all
Just a quicky
My Libra draws 0.13 amps when tested with the immobiliser on. Is that about right?
| posted on 11/10/15 at 02:51 PM |
130ma is way on the high side unless the battery is oversized , healthy and fully charged you could be looking at starting problems and battery
damage after less than 2 weeks lay-up.
Even on modern high end cars with lots of computer systems normally measuring an hour after shutdown I would regard anything over 30 ma as a problem
15 ma or less is more typical.
Smoking Frog
| posted on 11/10/15 at 03:11 PM |
I'm assuming standby current drain. According to this site it's to high.
http://www.w8ji.com/battery_and_charging_system.htm
About half way down it says "but in no case should "overnight off" leakage exceed 25 mA or so". Your's is 0.13A =
130mA
What's the current drain without the immobiliser connected as they may be another source of leakage.
rdodger
Ok Thanks.
I thought that might be the case.
I suppose I better start by removing the crapola alarm and test again.
theduck
| posted on 11/10/15 at 03:35 PM |
What is the correct way to measure this? I've been leaving my battery disconnected as a precaution and was considering a battery cutoff switch
so would be useful to know what the draw is.
rdodger
| posted on 11/10/15 at 03:40 PM |
Meter set to Amps (mine has a plug for the + lead 10 amp fused). Disconnect the + Lead from the battery and bridge the battery and + lead with the
meter.
| posted on 11/10/15 at 04:07 PM |
If you have a cut-off switch measure across the cut-off switch with the cut-off switch off..
