Mr.P
| posted on 27/12/20 at 08:05 PM |
TPS Wiring Omex 600
I am swapping my Carbs to Omex Throttle bodies on my 2.0 Zetec
I have pretty much completed the wiring however I have the TPS plug to wire in, Pink Grey and Orange
I have this plug
https://www.burtonpower.com/omex-throttle-position-sensor-wiring-connector-omem4053.html
Does anyone know the order they go in please??
IanmK
| posted on 29/12/20 at 11:51 AM |
Omex advise-
https://ibb.co/P6p6Dtq
IanmK
| posted on 29/12/20 at 11:52 AM |
Hence it depends on what TPS you're plugging it into and the direction you need to rotate it from fully closed to fully open.
best to test as explained above before wiring the plug, else you may need to re-pin it etc.
