Author: Subject: Garden Shredder - improving exhaust
Sarah
Contributor
Posts 88
Registered 12/5/21
Location Kent
Member Is Offline
Photo Archive Go!
Building: Restoring Rover SD1, rebuilding myself, sold Locos
posted on 19/7/25 at 11:59 AM Reply With Quote
I have one of these https://forest-master.com/compact-petrol-wood-chipper-6hp-direct-drive/ shredder, and though it's great for the shredding part, it has a tendency to block in the "exhaust".
So, looking at the shredder side, you'll see a bit of tube with a plastic cover. This houses a nut and locknut.
I have had the idea to have a centrifugal fan (connected via socket over locknut) and housing (with mounting via tube clamp over above tube) blowing into bottom of exit housing - it'll be helpful if I need blow shreddings over a hedge!
Trouble is, I have no idea how to size the fan, any ideas please? Motor no load speed is about 3500 rpm
jacko
posted on 21/7/25 at 06:53 PM Reply With Quote
Sorry but I can’t see a tube with a plastic cover except the oil filler
Can you explain a bit more please
Jacko
555
Sarah
Contributor
Posts 88
Registered 12/5/21
Location Kent
Member Is Offline
Photo Archive Go!
posted on 21/7/25 at 08:33 PM Reply With Quote
Hopefully this will help :
[img] Description
[/img]
jacko
posted on 22/7/25 at 01:21 PM Reply With Quote
I see now , would it be better with a electric fan I suppose it depends on electric supply
Would the drive of the lock nut be safe ?
Good luck if you manage to sort it out
Let us know how you get on
Graham
555
