planetester
| posted on 22/2/05 at 12:09 PM |
Escort Gauges
Can someone please help me, my donor car was a 1300L escort & did not have a tachometer, I have aquired a dash from a Sport but I'm stuck on
2 wire connections for the rev counter, I know one is ignition feed( black yellow & one goes to the distributor side of the coil but dont know
which way round, on the attache photo I know the top connection is panel lights, the bottom one is earth, but which way round are the middle two
thanks all
Marcus
| posted on 22/2/05 at 08:50 PM |
Just done the same thing, can't remember for the life of me which way round they are, will have a look in garage soon!!
Marcus
Marcus
Because kits are for girls!!
Marcus
| posted on 22/2/05 at 08:59 PM |
Ok Been to garage, 3 connections to rev counter, on the 3 nuts. Left - Ground, Centre - Ignition feed, Right - Trigger.
If you want it from the 4 way connector, from the top: Light feed, Ignition feed, Trigger, Ground.
Hope that helps.
Marcus
Marcus
planetester
| posted on 22/2/05 at 10:59 PM |
you are a true gentleman
thanks, I owe you one
