cerbera
| posted on 21/5/05 at 02:43 PM |
Connecting a speedo
I have two wires coming from the magnetic sensor that I am using for my Revotec speedo but on the wiring harness for the speedo there is only one wire
to connect the sensor to.
Am I supposed to connect both wires from the sensor to the one from the speedo? Im no auto electrician but that seems odd.
The only remaing wires that I have not used are:-
Harness reset switch
Pull up/down
speed signal (hall/ecu)
Im sure these have nothing to do with the magnetic sender.
[Edited on 21/5/05 by cerbera]
jack trolley
| posted on 21/5/05 at 03:31 PM |
1 to the speedo, the other to Earth.
cerbera
| posted on 21/5/05 at 03:50 PM |
DOH! That should have been obvious.
Thanks.
Avoneer
| posted on 21/5/05 at 08:25 PM |
Or one to +12v and the other to the speedo - that's how my greengauge one works.
Pat...
indykid
| posted on 22/5/05 at 08:13 AM |
my telemetrix speedo needed the positive pull up connected to function as well.
my reed switch is a switched earth also.
hth
tom
