silex
| posted on 26/5/05 at 03:52 PM |
New front / rear lights
Just had the Britax rep here in work and he was showing me a new range of lights they have very recently introduced. There are the L15 Series 75mm
lights.
View their bumf on the attached link
http://www.britax-pmg.com/prodguid1/2005Cat2LR03/Slide4.GIF
Thought they may be of interest.......
Murphy's 2 laws
1. If it can go wrong it will
2. In case of emergency - refer to rule 1.
mangogrooveworkshop
| posted on 26/5/05 at 04:01 PM |
I posted those a long time back under hamburger leds. Very tasty but a tad expensive at 65? squid What did he quote you. edit a price of 47 quid
each for the L14 12v led "hamburgers
http://www.locostbuilders.co.uk/viewthread.php?tid=18536
[Edited on 26-5-05 by mangogrooveworkshop]
silex
| posted on 27/5/05 at 06:54 AM |
I wasn't refering to the L14 series LED lights - LED lights are still expensive beacause of their limited take up at this time.
I was refering more specifically to the L15 series incandescent lamps which will be cheaper. I cannot give you the prices quoted to me as due to the
quantities involved it would be meaningless to an individual buyer. However, I would estimate that you would still probably be paying less than half
the price quoted on the L14 series LED lamps for an individual set.
Also the L14 series are 140mm diameter (as combination lamp or individuals), where as the L15 series 75mm diameter - another reason for the cost being
considerably lower.
They are e-marked and use a robust snap fit to panel system rather than the normal bolt on solution.
If there is any interest, I can get quotes for individual lamps at one off purchases to give people a better Idea.
Murphy's 2 laws
