Author: Subject: speedo healer
OX
posted on 29/5/05 at 07:11 PM Reply With Quote
speedo healer
ok my speedo needs to be set to 36% positive but i can only set my speedo healer to negitive it wont save the settings if its positive. i cant change the mph to kph or vice versa .iv tried a m8s SH and that did the same thing.
am i doing something wrong .my dad and i have been trying for the past few hours but still cant sort it out
any help would be brilliant
athoirs
posted on 29/5/05 at 09:07 PM Reply With Quote
I had to set pos on mine.. no problems..
all the switches should end up being off.. or it wont save...sw 3 being the pos/neg one..bomb proof bit of kit as far as I know
OX
posted on 29/5/05 at 09:51 PM Reply With Quote
thats weird becouse my m8s mk r1 indy is set to neg 35%,but the diff is a 3.92 and he's using 15"wheels,his is the one i used to see if mine was broken,but i couldnt set his to positive either
i can set the SH to pos 36% and when i pull the last dip switch down the little light flashes 3 times but once iv turned the ignition switch off and then on again the SH hasnt stored the settings,the only way i can store a setting is to have neg % which isnt anough
OX
posted on 30/5/05 at 02:39 PM Reply With Quote
sorted it now,both SH are faulty,just had to give the SH a permanent live feed
posted on 30/5/05 at 09:18 PM Reply With Quote
What are you?
posted on 30/5/05 at 10:07 PM Reply With Quote
Clever devil.
He is now anyway.
OX
posted on 30/5/05 at 10:08 PM Reply With Quote
he he the bloke from speedo healer said its a problem with the firm ware on v2.1,he said most bikes need to be neg ,i can send it back and they will change it
