MautoK
| posted on 10/6/05 at 12:45 PM |
High-level brake light position
Can anyone tell me the location limits for a high-level brake light?
I can't find any dimension quoted in the SVA draft or anywhere else.
I would like to fit it at the top of the rear panel (cutting a slot just under the top lip) which puts it about 720 mm above ground level. One of the
benefits is simpler wiring, not having to go through the roll-over bar.
But it doesn't really look as if it's high enough to be considered 'high'.
Otherwise it's going to be a fabricated housing to hang under the roll-over bar.
Cheers, chaps.
silex
| posted on 10/6/05 at 04:05 PM |
As far as I am aware, as long as your normal brake lights are in the correct position auxillary brake lights can go just about anywhere you like as
long as they comply to the following:
1. They are not forward facing
2. They were not designed for another intended purpose (i.e. you cannot fit a spare set of rear fog lights and pretend they are aux brake lights)
If its a purchased off the shelf aux brake lamp you should not have any trouble at all.
Murphy's 2 laws
1. If it can go wrong it will
2. In case of emergency - refer to rule 1.
MautoK
| posted on 13/6/05 at 08:16 AM |
Thanks, Mr Silex.
It's an LED strip unit from sVc.
