harvey115
| posted on 18/6/05 at 04:13 PM |
wiring loom
can anybody give me phone number for anybody good at making wiring looms please
rayward
| posted on 18/6/05 at 04:51 PM |
where are you located, if close enough, i could make you one.
Ray
James
| posted on 18/6/05 at 05:20 PM |
If it doesn't work out with Ray doing it for you then Premier Wiring:
http://www.premierwiring.co.uk/
make a fantastic Sierra donor loom for ~£100.
I've just fitted one and it's been really easy. They'll even customise it for you if you need.
James
[Edited on 18/6/05 by James]
- Muhammad Ali
zetec
| posted on 18/6/05 at 08:49 PM |
Second that, never heard a bad word said against them. Give them a call with what you need and they will go thru the options. With wiring it's
hard to sell a loom that will work on every car but Premiers seems to work for most.
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
hearnia
| posted on 18/6/05 at 09:34 PM |
I've got a Vicki Green wiring loom for sale if you're interested. Brand new untouched, looking for £70.
Joe
wilkingj
| posted on 19/6/05 at 07:17 AM |
I got the Premier Sierra based loom.. Can agree.. very good, and its the 3rd loom I have had.
Two both for my Land Rovers, from Autosparks, very good, but dont do kit car looms.
Premier one is good. Documentation could be better, But read it thoroughly, as its all there, once you grasp their style of writing. not a problem
really..
Both companies are top notch ones for service and help.
Best Regards
Geoff
http://www.v8viento.co.uk
| posted on 19/6/05 at 04:45 PM |
I've used a Vikki Green Sierra loom from lolocost. It's easy to install and connect up and comes with a useful schematic with lots of
Sierra info. I did have to wire in relays for headlights, horn and fan, but that's really very simple once you see how a relay works.
HTH
Nick
harvey115
| posted on 19/6/05 at 07:02 PM |
hi hearnia were you based im running a 2litre zetec on bike carbs with a megajolt system would alot of the loom be wasted?
hearnia
| posted on 19/6/05 at 08:12 PM |
I'm in Ashford in Kent.
Not 100% about what you would need from the loom, its the one MK supply, and is based around a pinto engine I believe.
