smart51
| posted on 5/8/05 at 06:46 PM |
Fuel level sender wiring
I have a VDO fuel gauge and sender. The both came without instructions. The gauge has terminals for the lamp - easy, plus 3 others, labled +, - and
S. 12V, ground and signal I should think. The fuel gauge is just a variable resistor with 2 terminals. Should this connect to 12V or ground?
stevebubs
| posted on 5/8/05 at 08:08 PM |
senders are pretty much always relative to ground.
[Edited on 5/8/05 by stevebubs]
Dusty
| posted on 5/8/05 at 08:13 PM |
+ is 12v ignition on supply.
- is earth.
S is to one terminal on sender.
Other sender terminal is to earth.
nanosleep
| posted on 5/8/05 at 08:16 PM |
Plug the gauge into 12V (+ terminal) and ground (- terminal). Leave the signal terminal unconnected. Then measure the voltage on the signal terminal
with respect to ground. If it reads 12V then I believe you should connect the signal terminal to your sensor, and the other side of the sensor to
ground.
HTH
-Andy
2000 Mustang GT
2003 Mustang Cobra 450RWHP/450RWTQ
2004 ZX-10R
In progress: 67 Mustang with 520ci(8.6L) V8, 600HP estimated
smart51
| posted on 6/8/05 at 06:38 PM |
Excelent! thanks.
