greggors84
| posted on 7/8/05 at 11:52 AM |
Flasher Relay
Im using a premier wiring loom with sierra stalks. I went and bought a flasher relay from halfords as my local scrappy were charging almost as much
for used ones. First of all i picked up the wrong one as it was on the wrong hook, i only realised when i took it out the packaging and realised it
was only a 2 pin. I tried it anyway and the hazard works fine with all the lights flashing. But the stalks dont do anything.
When i went to get the correct sierra one with 3 pins, i put it in and the only thing that happens is the hazard light comes on when its clicked
on.
When the 2 pin one is in the earth isnt connected which seems strange. Is there an easy way to test the stalks, to make sure they work?
Chris
The Magnificent 7!
greggors84
| posted on 7/8/05 at 04:21 PM |
All sorted now, the relay was connected wrong and i was missing a fuse!
Now have a problem with main beam flash.... (see other post)
[Edited on 7/8/05 by greggors84]
Chris
The Magnificent 7!
