Author: Subject: which loom?
redeye
posted on 12/8/05 at 10:30 PM Reply With Quote
which loom?
Ive decided to buy a new loom after the old escort loom i got with my car went up in smoke a few days ago.
I was wondering which loom is the best between the vicki green and premier wiring looms?
any suggestions?
cheers
James
posted on 12/8/05 at 11:31 PM Reply With Quote
Put it this way:
Premier Loom: great quality, easy to install (even for a complete beginner like me), loads of help (if you need it!) from PWS. Highly recommended.
Vicky Green: a little bit cheaper, a few people on here with problems with it, less support, I've seen atleast one person give up with it and buy a Premier one.
Clear enough!
James
redeye
posted on 13/8/05 at 07:37 AM Reply With Quote
cheers james
I was edging towards the premier wiring loom to begin with but that definitely helps
thanks again
Stuart Ainslie
posted on 13/8/05 at 08:19 AM Reply With Quote
I've got an AutoSparks one - Pretty straight forward and no problems...
wicket
posted on 13/8/05 at 11:47 AM Reply With Quote
We have used a Luego loom, everything worked 1st time with the exception of the hazard lights and that was due to a chassis connection not being made and that was not a loom fault.
Easy to fit and simple 'what goes where' connection sheet provided.
Bundles of wires labelled and comes with a fuse box
posted on 14/8/05 at 08:24 PM Reply With Quote
Just for balance...
I've used a Vikki Green loom in my Pinto engined Indy. It was a good price (£75) and works fine. It was easy to fit and came with a pretty comprehensive set of fitting plans.
I haven't had to call for help, so can't comment on the support available.
Nick
