fellowes
| posted on 16/8/05 at 03:17 AM |
Daihatsu Charade Alternator
I've heard that the 1.3L (or is it 1.6L) alternator for the Daihatsu Charade is very small and has a slightly longer spindle shaft than the 1.0
L. What is the amp rating on this? What year car was it fitted on? Is it the 1.3 or 1.6L?
Chaz
| posted on 16/8/05 at 08:41 PM |
45 amps i think on the 1.3 16v, not sure what yr?
givemethebighammer
| posted on 18/8/05 at 12:31 AM |
Mine came off a 1.3 16v, works well with the 2.0L zetec. If I remember the 1.3 version has a 5 rib poly v pulley and the 1.0 has a standard single v
pulley. Either way you will probably end up throwing the pulley away and fitting one to match your engine.
amps - not sure but mine works OK charging the Fiat chiquchento (is that how you spell it ?) battery, I have fitted.
Tigger
| posted on 19/8/05 at 09:14 AM |
Mine came off a Diahatsu "Mover". Most of the Diahatsu range look the same i.e. all small.
Also the Toyota Starlet alternator is equally small and light so that is another option.
Tigger
