darrens
| posted on 23/8/05 at 05:53 PM |
RV8 EFI ECU I/O diagram
Long shot, but does anyone have a input/output list/diagram for the RV8 ECU. Just starting to draw out loom for car as I'm not using original
sierra one and I'm using a RV8 EFI. Can't be arsed with removing sierra one, taking it out/cleaning or buying a new one. So building
own.
Darren
blueshift
| posted on 23/8/05 at 05:59 PM |
I have a few diagrams and know them fairly well as I had to rewire most of my RV8 EFI. They vary slightly by age I think. All my diagrams are on paper
and I don't have a scanner.. what is it you are after? Do you have an ECU and engine loom to go with it?
darrens
| posted on 23/8/05 at 06:26 PM |
I have an ecu which has the wiring snipted off, so 've decided to start everything from scratch to keep continuity throghout the car.
Darren
mark chandler
| posted on 23/8/05 at 08:02 PM |
If you recover a the out of a rangerover its complete, you just need to provide earth, power and wire to the fuel pump, unplug under the dash and pull
the whole lot through the 2" gromet hole.
Lots of diagrams on the net, searching under rover SD1 gets better results.
Anyway, that aside I,ve an old loom you are welcome to if you cover the postage, its a bit crispy where the heat from the engines got to it.
blueshift
| posted on 25/8/05 at 03:11 PM |
Your engine should have injectors, sensors, etc on it with most of the wiring loom. unless the wires have been snipped off EVERYTHING which seems a
bit harsh.
