silex
| posted on 15/9/05 at 06:57 AM |
Savage switches - well sort of.
Thought this may be of interest........
From a company called APEM Switches, but looks more extensive than Savage. Colour lights include blue, green, red, amber, white, plus a good quantity
of symbols.
Sorry for large pic
[img]http:// [/img]
As APEM manufacture switches, this may be Savages supplier.
[Edited on 15/9/05 by silex]
Murphy's 2 laws
1. If it can go wrong it will
2. In case of emergency - refer to rule 1.
Doh!Nut
| posted on 15/9/05 at 07:57 AM |
And Stainless steel keyboards for the ultimate PC in garage bling
http://www.apem.co.uk/pdf/steel.pdf
wicket
| posted on 15/9/05 at 09:17 AM |
APEM make very nice switches, we use a lot of PCB mounted push button switches at work. Free samples are usually available (you might have to spin a
bit of a yarn), but you will probably only get 1 not a dash board full !!
RichB
| posted on 15/9/05 at 11:46 AM |
I presume these (and savage switches) are ok for SVA?
omega 24 v6
| posted on 15/9/05 at 11:47 AM |
MMMmm says 24volt led backlight are they available in 12v
silex
| posted on 15/9/05 at 11:58 AM |
12 Volt LED versions are available, to have back-lighting and full illumination when on requires the optional resistor pack to be fitted.
Or just add your own resistor.........
Murphy's 2 laws
Dale
| posted on 15/9/05 at 12:09 PM |
Alan bradley make some very good ones as well. I will probably end up using one as a start and kill buttons on mine. Well we have and endless
supply of them here as well so that helps.
http://www.ab.com/industrialcontrols/products/push_buttons/22mm/800F_operators.html
Dale
[Edited on 15/9/05 by Dale]
Dale
my 14 and11 year old boys 22
and 19 now want to drive but have to be 25 before insurance will allow. Finally on the road
Nitrogeno25
| posted on 18/9/05 at 08:14 PM |
They look very good.
What It seems difficult to find are switches with 2 on positions (off-on-on) for lights, 2 speed wipers or 2 speed heater.
What are you guys using in these cases?
RazMan
| posted on 19/9/05 at 09:21 PM |
They should be as they have a radius on the buttons IIRC.
Is there a UK distributor for these?
Raz
