Gav-locoblade
| posted on 24/9/05 at 08:35 PM |
Fireblade clocks
Does anybody know if my speedo will be correct or not?
I have built a locoblade and used the original fireblade clocks it's a 1998 with the electronic speedo but I don't know wether the speed
will be correct or not.
I have 195/50/R15's. Please help.
| posted on 24/9/05 at 08:54 PM |
Basically no as the diff ratio will be different to the bike ratio.
You'll need a speed converter such as SPEEDOHEALER or something equivalent.
You'll need to calibrate it using another car or accurate means of testing... it's easy enough though will cost you about £70 for the
priviledge.
HTH
Ooops
[Edited on 24-9-05 by Hellfire]
Avoneer
| posted on 24/9/05 at 09:45 PM |
Yep, Speedohealer as per Hellfire said - that's the easiest way to do it.
Pat...
