smart51
| posted on 2/10/05 at 02:52 PM |
indicators on long stalks
I need some e marked indicators on long stalks. Where can i get some? from tip to tip they need to be 145mm or more.
jos
| posted on 2/10/05 at 03:40 PM |
Any motorbike shop will be able to sell them to you. When do you need them for. Ive got a pair of indicators mounted on extension stalks which will
be available after my SVA (which wont be soon). If you need them for a short time just to get through SVA perhaps you could borrow them.
richardR1
| posted on 2/10/05 at 04:13 PM |
Loads of them on ebay. These are the same as I got and just made up some extensions for them
http://cgi.ebay.co.uk/CARBON-MINI-INDICATORS-CLEAR-LENS-BRAND-NEW_W0QQitemZ8002669648QQcategoryZ25628QQrdZ1QQcmdZViewItem
MK Owners Club Member 1015
smart51
| posted on 2/10/05 at 06:23 PM |
Went to my local bike shop, and halfords. They do "long" and short ones but none long enough. They're all 90 or 100mm and I need
150 or so.
It was the making of an extension that I was finding difficult. It needs to be hollow, for the wires and have an 8mm (I think) thread tapped in one
end, to screw onto the light and an 8mm external thread for the nut on the other. easy if you have a lathe.
I thought that as so many people need these for SVA that you might be able to pick one up "off the shelf".
wicket
| posted on 2/10/05 at 07:04 PM |
Have a look at the Luego site Cars\Velocity\Build manual\Stage 10\front light fittings.
I have done mine like that and they worked out fine
jos
| posted on 2/10/05 at 08:04 PM |
www.s-v-c.co.uk go to more lights and under L874 PEDESTAL INDICATOR youll find soem that are 120mm long, any use?
[Edited on 2/10/05 by jos]
indykid
| posted on 2/10/05 at 09:48 PM |
get an m8 nut, and knock it into the end of a piece of 15mm copper pipe. it will deform the pipe so making it captive against rotation. a bit of super
glue and it's fixed in. do this with the other end once cut to the right length
now drill a 5mm hole down an m8 bolt. 8mm hole in the nosecone, and bolt it through, having previously threaded the wires through. connect up, and
marvel at your handy work.
and robert's your dad's brother
tom
P.S i accept no responsibility if this doesn't work. it was an ian brown kit tip from which kit?, and based on his other 'gems'
it's probably a load of old tosh, but does look better than most stuff he comes up with.
[Edited on 2/10/05 by indykid]
BKLOCO
| posted on 3/10/05 at 08:41 AM |
Indykids answer will work. I came up with the same solution but used 15mm plastic pipe and araldited the nuts in. The plastic pipe was allready black
matching the colour of the indicator stalks.
