Howlor
| posted on 8/10/05 at 08:58 PM |
Headlight Plug Wiring
Wiring my headlights up and just wondered if anyone can shed any light! as to which terminal is which on a double filament 3 pin halogen headlight
bulb? Also does anyone know the same for a brake/tail light connection with the offest bayonet pins?
bob
| posted on 9/10/05 at 02:03 PM |
Colours may depend on your loom but here is how mine worked,the yellow was dip beam (horizontal spade) the white was main beam (vertical spade)(right)
and the other vertical spade brown earth.
I got the brown earth and white main beam around the wrong way 1st time but it'll either work or it wont.
This was using a premier wiring loom which normaly matches up to ford sierra wiring.
