Northy
| posted on 1/2/03 at 09:44 AM |
Mk 1 Sierra Column Switches
Am I correct in thinking that the Mk 1 Sierra Column Switches have the horn on the end of one of the stalks? And that no relays are used to switch the
lights, all current goes through the (beefier) switches in the column?
paulf
| posted on 2/2/03 at 11:40 PM |
I have used MK1 sierra switches and the horn switch is on the end of the indicator stalk, I hope you are correct about no relays because that is the
way i have done mine, mk3 escort switches also appear to be identical apart from the offset of the stalk from the steering wheel is different.
Paul
jollygreengiant
| posted on 3/2/03 at 07:05 AM |
Where the horn switch was on sierra's depended on the trim level. Base up to GL was indicator, Gl upwards was on the steering wheel.
Some had relays some didn't. If you use the horn a LOT, then expect to burn out the contacts in the switch occasionaly (2/3 years-ish, put a fuse in
supply just in case)
