dhollin3
| posted on 9/11/05 at 01:58 PM |
Relay Problems
Afternoon All,
I was having a few problems wiring my Locoblade last night as the indicator relays are being annoying.
The problem is that the Hazard relay flashes really quickly and the left or right indicator relay flashes very slowly. Is there any way of changing
this? Do i have to put a resistor in or do i have to change the type of flasher relay (wattage) to accommodate?
Dom
dhollin3
| posted on 9/11/05 at 03:23 PM |
by the way - i have two seperate indicator relays, one for the hazards and the other for the directional indicators!!!
VinceGledhill
| posted on 9/11/05 at 03:57 PM |
sounds like the relays are the wrong way round to me.
Regards
Vince Gledhill
Time Served Auto Electrician
Lucas Leeds 1979-1983
dhollin3
| posted on 9/11/05 at 04:08 PM |
they are both the same type that i bought from Halfords! Do you think that i need to change them?
DarrenW
| posted on 9/11/05 at 04:12 PM |
Why did you use 2?
I used a single relay with a 2 pole savage switch for the hazards which basically switches both the left and right indicators on at same time without
linkingthem elctrically. Worked first time - no probs.
dhollin3
| posted on 9/11/05 at 04:31 PM |
The wiring loom I used suggested that there should be two relays.
With your solution Darren, did you use a two or 4 pin relay........i am not that hot on electrics by the way!!!
theconrodkid
| posted on 9/11/05 at 09:04 PM |
what front indicators have you got?if they are bike ones with 10 w bulbs and 2 pin relays they do this cos the loads are wrong and the relay cant
cope,3/4 pin relays are electronic and can compensate for different loads
who cares who wins
pass the pork pies
| posted on 10/11/05 at 12:01 AM |
Start again IMO...
Maybe use this drawing...
dhollin3
| posted on 10/11/05 at 07:33 PM |
Cheers for all your help.
I will give the three pin relay a go and see if it works.
My bought my loom, so i hopt that i don't have to create any extra bits to get the indicators working.
I might even give Ian gray (Stuart Taylor) a ring as the loom is from them, but i hate calling that place......
I will let you all know what i did to solve it.
dhollin3
| posted on 11/11/05 at 02:49 PM |
Solved.......two new relays with a higher wattage. The originals were 2 x 21w but the new ones are 4 x 21w and they are perfect. Strangly they have
slowed the hazards down and made the indicators faster. Like it!!!!
