Author: Subject: Digidash/Emerald
liam.mccaffrey
posted on 5/12/05 at 06:20 PM Reply With Quote
Digidash/Emerald
Electrics on my 7 are as follows
Premier wiring loom
Emerald ECU
Digidash2 lite
Ecotec on tb's
My question is can i use the same sensor to provide inputs to both the digidash and emerald eg coolant temp
I'm thinking not but just checking what ppl think
Build Blog
Build Photo Album
stevebubs
posted on 5/12/05 at 07:17 PM Reply With Quote
Unlikely as these work on resistance between ground and the sender terminal.
If you add another reference in there then there is no guarantee this won't introduce error.
DanP
posted on 5/12/05 at 07:55 PM Reply With Quote
Sorry to say you almost certainly won't be able to as both will work by trying to measure the voltage across the sensor when put in series with another resistive element and a voltage applied - connecting two different units to the same sensor would almost certainly cause incorrect readings without some sort circuitry in there to trick one of the units - although this feasible if you knew how the one you were trying to 'trick' worked. (I can think of one way to do it but you might find that doubling up on the sensors you need would be simpler)
Hope that helps
liam.mccaffrey
posted on 5/12/05 at 08:15 PM Reply With Quote
i thought as much which i would imagine why the digidash comes with all the sensors. theres no simple easy way to get 2 signal from a comparative resistancey thing.
no bother double up on sensors it is, i have them all anyway
Build Blog
Build Photo Album
lsdweb
posted on 5/12/05 at 10:24 PM Reply With Quote
Hi Liam
Join the club! Emerald and Astradash - two sensors for water temperature - I'm no sure what else will 'double up' yet as I haven't worked out what's what on the Blackbird engine!
liam.mccaffrey
posted on 5/12/05 at 11:24 PM Reply With Quote
when you sold everything wyn i was hopingyou might sell your emerald. you keeping it with the bird engine?
I thought it was possible but i hadn't heard of anyone doing it. I hope it is because i'd love to bike engine something
[Edited on 5/12/05 by liam.mccaffrey]
Build Blog
Build Photo Album
lsdweb
posted on 6/12/05 at 08:24 AM Reply With Quote
Hi Liam
I plan on using the Emerald system on the Bird engine although this isn't going to be simple! See here for a thread on this
The main reasons for staying with the Emerald system:
It's very good!
I've got one!
The Bird engine is a carb version but I'm fitting throttle bodies (Suzuki GSXR 1000 which fit and the Bird injected engine ones don't!!). You'll soon see a set of Blackbird carbs and throttle bodies up for sale! So I'd have no chance using the Honda management system anyway.
I'll let you know how I get on.
Regards
Wyn
Syd Bridge
posted on 6/12/05 at 09:10 AM Reply With Quote
Premier wiring loom
Emerald ECU
Digidash2 lite
Ecotec on tb's
Easy enough to do. Again, I see it often in my work, one sensor feeding a couple of instruments, particularly multiple daq's. Just need to feed the voltage to an opamp wired as a voltage follower, then on to as many instruments as you want.
Initial voltage feed to the opamp is from a parallel to the major instrument.
Syd.
NS Dev
posted on 6/12/05 at 09:59 AM Reply With Quote
do you really need a temp gauge?
can't you just drive an overtemp warning light from a spare output on the emerald ecu?
mstepien
posted on 11/1/06 at 05:30 PM Reply With Quote
Syd,
Could you direct me to some more info on the duplication of the signal from sensors ? I intend to use an Emerald and, in due time ;D some datalogging box and they're not always fully compatible.
Thanks,
Michal
