ayoungman
| posted on 10/1/06 at 02:57 PM |
fuel tank sender
Can I use any float based fuel sender unit. I don't yet have the fuel gauge so I have'nt got a clue if it is a must buy soon option or
not. Once the tank is in I really wont want to remove it to fit the sender at a later date.
"just like that !"
mookaloid
| posted on 10/1/06 at 03:11 PM |
As I understand it the float/sender unit in the tank must be appropriate for the gauge.
otherwise it won't work very well - if at all.
Mark
| posted on 10/1/06 at 03:18 PM |
Just about what Mark says - they have to be paired if they are to work properly.
| posted on 10/1/06 at 04:06 PM |
true and not true.
usually the sender is a variable resistor and is connected in series with the guage, whcih in effect is a ammeter.
if you know the rnge of restistance for the sender and the range of amps for the guage you can with some additional electrickery interface the two
together.
I have two defender guages for each underseat tank which have series senders (land rover talk) that are not compatible; I made simple op-amp circuit
to make it workable; it is still non-linear but is usable; ah yes, forgot to say that both the sender and guage linearity may not be compatible.
In short, use compatible sender/guages to avoid problems.
| posted on 10/1/06 at 04:22 PM |
true and not true.
Ah-hem
ayoungman
| posted on 12/1/06 at 10:54 AM |
I was looking at landrover series senders the other day. I could use a variable resistor and then 'tune' it to match the fuel gauge.
I've got a spare sender from the old tank on my 109 to play with.
thanks guys, I'll have a play and let you know how I get on
"just like that !"
| posted on 12/1/06 at 01:35 PM |
ah, if only life was that easy. to save you some time, here is some stuff you should know.
series guages were wiredto the voltage stabiliser so effectively run on 9 V (Defender guages run on 12 V).
next the senders, typically range is 30 - 300 ohm but there are different flavours, that my just apply to military one. I have senders that work in
opposite way; high resitance when empty whereas other is low resistance when empty.
so quite a few combinations. there is some non linearity i.e. the guage can read full for a long time even though it isn't then suddenly
start dropping to empty - don't really have a solution for that one.
