Author: Subject: Nice LED number plate lights - v. cheap....
Jasper
posted on 23/1/06 at 04:23 PM Reply With Quote
I just bought a pair of these lights from this chap in the US. He charges $12 each plus $3 to post them!! Demon Twats sells them for around £37 + p+p......
Lite n Boltz
They're the ones on the left.
DaveFJ
posted on 23/1/06 at 04:42 PM Reply With Quote
have seen an Avon with those fitted - just two
they passed SVA........
Dave
posted on 23/1/06 at 05:07 PM Reply With Quote
Very tasteful - nice and simple too!
Jasper
posted on 23/1/06 at 05:08 PM Reply With Quote
One each end is fine - seen one on another Stylus, small, neat and SVA friendly
Humbug
posted on 23/1/06 at 06:24 PM Reply With Quote
I saw some of the other lights in your link (the ones with the light coming out the end) in Halfrauds the other day, in the bling section. About £12 from what I remember... obviously no use for no. plates, thought
chriscook
posted on 30/1/06 at 08:10 PM Reply With Quote
Thanks for the tip off Jasper. Ordered some last monday and they arrived today. Was looking for these at sensible prices but hadn't found any before.
Chris
posted on 1/2/06 at 09:53 AM Reply With Quote
$12 each, hmmm ; how about this for truly locost solution:
1. buy chrome bezel for 28p from maplins:
http://www.maplin.co.uk/Module.aspx?ModuleNo=2073&criteria=led%20lamps&doy=1m2
2. file down the top so that LED is proud
fit white LED
3. fit 3 mm white wide angle LED
4. fit drop resistor
should be done for under £ 2.
chriscook
posted on 1/2/06 at 06:34 PM Reply With Quote
The number plate lights are not so easy unfortunately. unless you have facilities to turn them up and make the cutout in the side.
Chris
