Author: Subject: Misfire
GazzaP
posted on 20/2/06 at 08:07 AM Reply With Quote
Misfire
Hi all!!
did a trackday at Cadwell yesterday and found when warm and at 5000rpm i had a misfire would drop onto 2-3 cylinders then if i kept revving it would clear and run sweet. I checked everything over and found two large cracks in the dizzy cap. My question is would these two cracks cause a intermittant misfire.
Many thanks Gary
www.gmpmotorsport.co.uk
Howlor
posted on 20/2/06 at 08:39 AM Reply With Quote
More than likely. I had a car that did the same and that was a cracked cap.
posted on 20/2/06 at 11:38 AM Reply With Quote
If the cap's cracked it's a wonder it doesn't misfire all the time.
GazzaP
posted on 20/2/06 at 11:57 AM Reply With Quote
Well it was getting worse and worse so only did two sessions in the morning.
posted on 20/2/06 at 12:25 PM Reply With Quote
Swap the cap and rotor arm together when you do the job, it's not worth trying to save on.
GazzaP
posted on 20/2/06 at 12:27 PM Reply With Quote
Just been and ordered new items getting rotor arm aswell as there is not alot left of it!
