the_fbi
| posted on 26/3/06 at 10:01 PM |
Fuel tank sender, dip style.
Did a search which chucked up a load of different solutions, but none for a source of dip tube style senders.
Its a fuzzy picture and the length could be an issue, but this looks pretty good and cheap too.
There are 4 connections on the top which doesn't make sense....?
Thoughts?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=4616412978
ta
Chris
nitram38
| posted on 26/3/06 at 10:11 PM |
The trouble is the ohms. You will need to match it to your gauge or you will get odd readings.
The 4 terminals might be for a low fuel level warning light, plus gauge.
bimbleuk
| posted on 27/3/06 at 08:48 AM |
I gave up on the Smiths swing arm sender and bought a VDO gauge and dip tube sender instead. Ncely damped reading and you can pack the tank with foam
too which might help for track days.
I bought mine from Merlin Motorsport and got a length to suit my tank. Tank is 170mm deep the dip tube is 166mm long.
[img][/img]
the_fbi
| posted on 27/3/06 at 07:15 PM |
Rough idea of cost?
