DanP
| posted on 17/4/06 at 09:32 PM |
sierra ignition switch current rating?
having just seen the post regarding running the starter solenoid thru the ignition switch, does anyone know what current the sierra column ignition
switch is rated to (in position 2 specifically)? can i just run my ignition live wiring straight thru it or is it best to use it to switch a relay?
Cheers.
[Edited on 17/4/06 by DanP]
RazMan
| posted on 17/4/06 at 10:51 PM |
As the standard Sierra setup does not uses a relay there is no reason to use one - that includes the starter solenoid too.
Raz
MikeR
| posted on 18/4/06 at 11:40 AM |
eeek, thats a lot of current, I'd add the caveat that make sure your cables can handle it. Things like the Premier Wiring Loom probably expect a
solonoid.
RazMan
| posted on 18/4/06 at 12:58 PM |
solonoid.
AFAIK every setup uses a solenoid for the starter - just not a relay for the solenoid as it probably draws around 8 Amps which any 0.5mm2 cable and
switch should easily handle. The starter motor can draw up to 700 Amps which is why the solenoid is there in the first place - it is just another form
of relay.
Raz
