zxrlocost
| posted on 19/4/06 at 08:42 PM |
indicators flashing quicky on r1 loom
Hi Ive just wired my indicators up by extending the loom of the R1
problem is all work ok but flash to quick
sometimes they flash ok for a while but then back to flashing quick
any ideas even when all bulbs fuses are ok??
ta chris
dave1888
| posted on 19/4/06 at 08:45 PM |
What wattage of bulds are you using. They should all be about 21w. The lower the wattage the quicker they will flash.
k33ts
| posted on 19/4/06 at 08:51 PM |
its because youve got led rear lights youll need to put a resistor in to compensate.
or some more bulbs
[Edited on 19/4/06 by k33ts]
tukcustoms.com
zxrlocost
| posted on 19/4/06 at 08:53 PM |
LED with resistors on front
normal bulb ??watt on the back
and I wired a middle one into the right signal and they started to flash ok(right turn) for a bit then went back to flashing quick
they always flash quick when left signal
but no middle bulb wired into that one yet
ta chris
RazMan
| posted on 19/4/06 at 09:23 PM |
Have you got the resistors wired in series or parallel?
Raz
zxrlocost
| posted on 19/4/06 at 09:29 PM |
erm the resistors came with the front LEDs
they were on two seperate wires that extended onto the original wires
ta chris
RazMan
| posted on 19/4/06 at 09:40 PM |
So they are mounted in parallel which is correct. It sounds like a wattage / flasher unit problem. If you add up the total watts for one side, it
should equal around 52W. Assuming your repeaters are conventional lamps, the only iffy bit will be the resistor value. Do you know the value?
Raz
Ian D
| posted on 19/4/06 at 10:00 PM |
Have you checked you earthing arangements. A poor earth can cause rapid flashing.
Dusty
| posted on 19/4/06 at 11:04 PM |
SVC will sell you a relay that is not wattage sensitive.
zxrlocost
| posted on 20/4/06 at 08:25 AM |
ill have a look later and see if I can sort the wattage first
ta chris
zxrlocost
| posted on 20/4/06 at 08:57 PM |
sorted thanks with the wattage thing
Steve @ sVc
| posted on 25/4/06 at 01:30 PM |
Connect the indicator feed wire to the resistor and from the resistor to earth.
One each side.
The resistor is frequently fitted behind the dash and should have a heat sink.
Regards
Steve @ sVc
